SolarWinds Avior
Troubleshooting Platform Connect Plugin and Log Locations for SolarWinds Avior
This article lists the main connector and connector plugin log locations for Windows and Linux, explains how to check the Platform Connect server agent plugin status, and identifies where to capture browser-side diagnostics in the Avior web UI.
Use this article when troubleshooting an issue during installation of the Platform Connect agent in SolarWinds Avior. It explains where to collect the relevant logs and status information based on the issue.
If you encounter an issue during installation of Platform Connect agent, the following log locations are relevant depending on the error received.
Windows
- Main Connector Log: C:\ProgramData\SolarWinds\UAMSClient\log\uamsclient.log
- Connector plugin log: C:\ProgramData\SolarWinds\UAMSClient\log\plugins\platform-connect\default\connector-plugin.log
Linux
- Main connector log: /var/log/solarwinds/uamsclient/uamsclient.log
- Connector plugin log: /var/log/solarwinds/uamsclient/plugins/platform-connect/default/connector-plugin.log
Platform Connect Server Agent Plugin Status
- RDP or SSH to the server, open a web browser, and navigate to http://localhost:2113/status
Avior Web UI
- Press F12 to open Developer Tools, which can help capture possible front-end or authentication-related issues.
Installation Note: There is currently no manual installation method available. The onboarding process generates a sessionID that is unique to the onboarding session.
