Troubleshoot deleted Network Atlas maps in Orion Platform products
Active diagnostics detects 'Deleted maps and objects check'
10/29/2018 4:23 PM
2/4/2022 3:16 PM
When active diagnostics detects deleted maps and deleted maps objects in your Orion Platform products, delete these records from the database so that it does not affect Network Atlas from working correctly or crashing.
Orion Platform
Records for deleted Network Atlas maps and related objects have the IsDeleted flag set to 1 but not deleted from the SolarWinds Orion database.
To resolve the issues, delete records for deprecated Network Atlas maps and deleted maps objects from the SolarWinds Orion database:
  1. RDP to Main Poller
  2. Stop all services using the Orion Service Manager (Default location: C:\Program Files (x86)\SolarWinds\Orion\StopNetPerfMon.exe)
  3. Open Database Manager (Default location: C:\Program Files (x86)\SolarWinds\Orion\DatabaseManager.exe)
  4. Execute the following query:
    DELETE FROM MapStudioFiles WHERE IsDeleted = 1
  5. Run the Database Maintenance (Default location: C:\Program Files (x86)\SolarWinds\Orion\Database-Maint.exe)
  6. Start all services using the Orion Service Manager
By following these step's the deprecated map objects will be removed from the Orion database.
