Troubleshoot DHCP and DNS connection errors in IPAM
This article discusses troubleshooting steps to address the following issues encountered in IPAM: Bad username or password The RPC Server is Unavailable Insufficient permissions BIND Credential fails using ssh or telnet option BIND DNS on AIX Symptom
10/12/2018 8:15 PM
2/17/2022 6:51 AM
  • Bad username or password
  • The RPC Server is Unavailable
  • Insufficient permissions
  • BIND Credential fails using ssh or telnet option
  • BIND DNS on AIX Symptom
IP Address Manager
This error may occur when the valid user account on the Orion host has no meaning to the DHCP Server or when the provided password is not correct on the DHCP Server.
This error may occur when the DHCP Server is unable to receive or respond to RPC Requests.
When adding a DNS Bind, in the BIND Credential option there is a space in the Credential name. For example,
  Credential Name: Bind 1
  Username: root
  Password: 1234
BIND DNS on AIX Symptom: Bind is not running error when testing the connection to implement BIND DNS Mgmt and add an AIX 6.1 Bind9 based DNS Server
When the named-V and ps -A -o comm,pid,args | grep ^named commands are issued and parsing returns a value that does not match the criteria, the application is not enabled: named9 vs named
  • Verify the account used is valid on the DHCP Server.
  • Verify that the provided account and password is both identical and functional on both the Orion host and DHCP Server.
  • Verify that there is no firewall preventing the Orion host from performing RPC calls by checking with Administrator accounts that Windows file sharing is possible. An alternate way to verify is a telnet to the IP address provided in the Orion node on port 445.
  • If this occurs intermittently, verify that the DHCP server has enough client access licenses.
  • Verify that the provided user account is part of the DHCP Users group in the DHCP Server.
  • For Cisco DHCP, verify the requirements on Cisco DHCP device for Orion IPAM.
  • Remove the space in the 'Credential Name'.
Perform a manual configuration of the config file by renaming the file from named9 to named.
IPAM BIND Requirements
  • User account needs to be configured to allow remote telnet or SSH access to BIND machine.
  • Read and write file access is required for all BIND configuration files.
    • /etc/named.conf, and all included files
    • all zone data files
  • Read and write access to system temp directory /tmp
IPAM utilizes both standard Linux commands (POSIX) and BIND specific commands that are required for IPAM BIND management functionality.
named
ps
grep
sha1sum
cat
if [ -r "filepath" ] ; then echo 'true'; else echo 'false'; fi
if [ -w "filepath" ] ; then echo 'true'; else echo 'false'; fi
if [ $? -eq 0 ] ; then echo 'true'; else echo 'false'; fi
cp
mkdir
rm
named-checkconf
