Track SNMPv3 credentials that are assigned to a node in NPM
This article describes how to track SNMPv3 credentials that are assigned to a node.
10/17/2018 8:02 AM
9/4/2025 8:16 PM
If there's a need to track certain SNMPv3 credentials that needs to be updated on the system, the article will aid on how to track SNMPv3 credentials that are assigned to a node through the database
Network Performance Monitor
  1. Establish a remote connection to the SolarWinds server.
  2. Go to the Start Menu and search for Database Manager.
  3. Click Add Orion Server and expand your SolarWinds SQL Server.
  4. Click the drop down and expand your Orion database.
  5. On the expanded list of tables, locate the table named Credential.
  6. Right-click and select Query Table > Execute Query. The lists of credentials used on the SolarWinds application are displayed.
  7. Take note of the ID number for the credentials that you are looking for.
  8. Paste the following query: (Replace the hashtags (####) with the ID number found from the credential table list)
    SELECT NodeSettings.NodeID,Nodes.IP_Address,Nodes.DNS
    FROM [dbo].[NodeSettings]
    INNER JOIN Nodes on NodeSettings.NodeID=Nodes.NodeID
    WHERE SettingName LIKE '%SNMP%' AND SettingValue = '####'
  9. After determining the node IP or name, go back to the SolarWinds Platform Web Console, click on Manage Nodes
  10. Search the node, click on the check box, and then click on Edit Properties
  11. Replace the credentials set on the polling method.
