Top 10 Volume Percent Utilization - Exclude Physical and Virtual Memory on the list in NPM
This Procedure describes how to remove Physical and Virtual Memory listed on Top 10 Volume Percent Utilization Resource View.
10/30/2018 4:43 PM
3/16/2023 7:05 PM
This article describes how to remove Physical and Virtual Memory listed on Top 10 Volume Percent Utilization Resource View. This is useful when you would like to show only Fixed disk on Top XX Volume Percent Utilization.
Network Performance Monitor
  1. Go to your View and select the pencil icon in the upper left to Customize Page.
  2. Select Add Widgets.
  3. Type in the search box “Top XX Volumes by Disk Space Used. Click and drag the widget onto te page to its desired location.
  4. Select Done Adding Widgets > Done Editing.
  5. The widget will now display on the new resource view, to filter it only to Volumes click Edit.
  6. Add the following query to the filter box: VolumeType Like 'Fixed Disk*'.
  7. Click Submit.
  8. The widget will now only display the top 10 volumes by disk space.
