Tools
Tools missing from Toolset tab in Orion Web Console after implementing Hotfix 1 for Engineer's Toolset on the Web 11.0.1
After implementing HotFix 1 for Toolset on the Web 11.0.1, tools are no longer in the Toolset tab within the Orion Web Console. Instead of the tools you see the error: < There was an error rendering >. Clicking "View Details" shows < There was no response from the Toolset Service Engine located at [Orion Address]:17777 >.
After implementing HotFix 1 for Toolset on the Web 11.0.1, you no longer see the any tools in the Toolset tab in the Orion Web Console. Instead of the tools you see the error:
Clicking "View Details" shows:
- Extract the HotFix zip file to your desktop.
- Right-click the extracted SolarWinds.Toolset.BusinessLayer.dll file and click "Properties".
- Click the "unblock" button.
Once this has been completed, reimplement the HotFix using the following steps:
- Stop all Orion services using the Orion Service Manager.
- Copy the SolarWinds.Toolset.BusinessLayer.dll to Engineer's Toolset's installation location (default: C:\Program Files (x86)\SolarWinds\Orion\Toolset), replacing the current file.
- Start all Orion services using the Orion Service Manager.
