Monitor Arista switches and routers with multiple VRFs over SNMPv3 in SolarWinds UDT
This is to poll the IP Addresses from VRFs of Arista layer 3 capable switches and routers over SNMPv3 in SolarWinds UDT.
1/29/2026 9:53 PM
1/29/2026 10:16 PM
1. By design, standard UDT-based polling gathers information for both MAC and IP endpoints through SNMP polling of Bridge MIB-based OIDs, and it is not applicable to endpoints on a VLAN or a VRF.
2. For a VLAN or a VRF, UDT uses a context SNMP request against a device to gather information specifically for those VLANs and VRFs. This method allows it to gather information specific to a particular VLAN or VRF from a device that a standard poll would not.
User Device Tracker
For the Arista device configuration, detailed steps must be provided by your vendor. Arista configuration might vary by version of your Arista EOS:
1. Make sure you have this on the Arista device: "Create an SNMPv3 view, group, and user."
2. Define one SNMP context per VRF you want UDT to see.
On your SolarWinds Platform web console:
1. Add the Arista node in SolarWinds with SNMPv3.
  • In SolarWinds, go to Settings → Manage Nodes → Add Node.
  • Enter the management IP of the Arista.
  • Under SNMPv3 Credentials:
    • User name: sw-udt <- example user changed it according to your requirements
    • Authentication: SHA + <AUTH_PASSWORD>
    • Privacy: AES + <PRIV_PASSWORD>
    • Context: leave blank here (this is the default context for the base node).
  • Test the credentials; they should succeed.
  • Complete the wizard and ensure:
    • The node is polled by SNMPv3.
    • Under List Resources, routing/VRF-related resources are enabled if available.
2. Configure SNMP contexts (per VRF) for that node, all using the same SNMPv3 user but different context strings.
  • Go to Settings → Manage Nodes.
  • Find your Arista node → click its name → Edit Properties.
  • Scroll down to the SNMP / Additional Polling / SNMP Contexts section (label varies by version).
    You should see an option to add additional SNMP credentials/contexts.
  • For each VRF you exposed on Arista, add a row:
    • Protocol: SNMPv3
    • Auth/Priv: same as base (SHA + AES and the same passwords)
    • Context: the context string you configured, e.g.:
      • VRF-CUSTA
      • VRF-CUSTB
  • Save/Submit.
3. Wait for 30 minutes for your UDT to poll the IP addresses information from your VRF via SNMPv3 context polling.
