Application Management
Causes of unparsed messages in Loggly
This article helps to identify the causes as to why your expected message format in Loggly is unparsed.
Unparsed messages are unformatted key values that cannot identify the value in an input field. If the log message is unparsed, the messages will not be indexed in key-value field format.
1. You received a Max Field notification if you already exceeded the field limit.
2. You encountered Mapping Conflict notifications if the fields on the events are not indexed or parsed.
3. You may be using an unsupported log format type.
1. Max Field Limit
2. Mapping Conflict
3. Automated Parsing Log Types
