There is a sudden problem with your licensing system. Contact SolarWinds technical support
Unable to activate your license because your License Manager was corrupted. If you open your Solarwinds License Manager, the following error is seen: There is a sudden problem with your licensing system. Contact SolarWinds technical support.
10/18/2018 7:17 AM
12/20/2021 8:10 AM
Unable to activate a license because License Manager was corrupted and following error message is displayed:
Network Performance Monitor
  1. If the license is activated, request to have it reset or deactivated.
  2. Uninstall License Manager.
  3. Download License Manager directly from the web because the .exe installer file on your server is corrupted.
  4. Reinstall SolarWinds License Manager.
  5. Have the license activated again.
