Security Compliance
The suppressSids setting for the Recertification summary does not work in ARM 2026.2.
This article describes a bug in ARM 2026.2.
The permissions of the SIDs declared in the related config entered in the pnServer.config.xml file as shown in the below example will not be hidden from the Recertification summary of a share, after the update to ARM 2026.2.
<fileSystem>
<recertification>
<suppressSids type="System.String">S-1-5-21-2XXXX9978-83XX52521-250XX22306-XXX1;S-1-5-21-20XXXXX78-8XXXX2521-XXX322306-14XX1
</suppressSids>
</recertification>
</fileSystem>
This has been identified as a known issue in ARM 2026.2.
This issue will be addressed in a future release of ARM.
