The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found
This article addresses the following error that is displayed when opening the Orion Web Console: The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found System.Configuration.SettingsPropertyNotFoundException: The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found. at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName) at System.Configuration.SettingsBase.get_Item(String propertyName) at System.Web.Profile.ProfileBase.GetInternal(St
The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found System.Configuration.SettingsPropertyNotFoundException: The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found. at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName) at System.Configuration.SettingsBase.get_Item(String propertyName) at System.Web.Profile.ProfileBase.GetInternal(String propertyName) at System.Web.Profile.ProfileBase.get_Item(String propertyName) at System.Web.Profile.ProfileBase.GetPropertyValue(String propertyName) at SolarWinds.Orion.Web.UI.OrionView.SelectView() at SolarWinds.Orion.Web.UI.OrionView.OnPreInit(EventArgs e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
C:\Inetpub\SolarWinds\Orion\TrafficAnalysis\ TrafficAnalysis.config file.Resolution
- Repair NTA from Windows Programs/Features. For instructions, see Uninstall, change or repair a program.
- Run the Configuration Wizard in full mode:
- Select
Website, Database, Serviceswhen prompted. - Do not skip Website Optimization.
- Refer to Run the Orion Configuration wizard .
- Select
