Applications Systems
The remote configuration was not successful. WinRM test failed. Connecting to remote server MACHINENAME failed
The WS-Management service cannot process the request. The following error message is received: The remote configuration was not successful. WinRM test failed. Connecting to remote server MACHINENAME failed with the following error message : The WS-Management service cannot process the request. Cannot find the Microsoft.PowerShell session configuration in the WSMan: drive on the MACHINENAME computer. This is typically found when assigning the AppInsight for IIS or AppInsight for Exchange application templates.
- Winrm is not setup or
- TrustedHosts on server are not set.
Register-PSSessionConfiguration -Name Microsoft.PowerShell
