"The passed sql identifier contains invalid characters or is too long" error in Cortex during initialization and Nodes assigned to a specific APE are not polled in SolarWinds Platform
Nodes assigned to a specific Additional Polling Engine (APE) fail to be polled due to a Cortex error. However, when these nodes are moved to the Main Polling Engine, polling works as expected.
- Historical performance charts (e.g., CPU, memory availability) do not load for nodes monitored by a specific APE.
- Moving the affected nodes to the Primary server or another APE resolves the issue.
- Cortex Persistence logs on the affected APE show errors indicating failure during initialization.
ERROR Persistence.SolarWinds.Cortex.Internal.Persistence.PersistenceSubsystem - Initialization of Persistence failed: System.ArgumentException: The passed sql identifier contains invalid characters or is too long (maximum of 100 characters): ElementId
Parameter name: identifiers
ERROR SolarWinds.ServiceHost.Internal.ServiceLifetimeTracker - Service SolarWinds.Cortex.Persistence - (Cortex) crashed. Going to restart service in 00:00:30
- System Locale:
tr; Turkish - Input Locale:
tr; Turkish
- English
- German
- Japanese
- Simplified Chinese
- Change System and Input Locale on the Affected APE
- Update the system locale and input locale to a supported language, preferably English (United States).
- This change must be applied not only for the current user but also for all service accounts running SolarWinds services on the APE.
- Use
msinfo32.exeto Verify and Change Locale-
- Run
msinfo32.exeon the APE server. - Confirm the locale is set to US English or change it accordingly.
- Run
Database Cleanup and Configuration
- Truncate the
Cortex_Documenttable in the SolarWinds database to clear corrupted or incompatible data. - Run the SolarWinds Configuration Wizard on the affected APE to reinitialize services and complete configuration.
- Truncate the
After applying the locale changes and running the Configuration Wizard, monitor the Cortex Persistence logs to confirm the error no longer occurs. Verify that nodes assigned to the APE are polled correctly and historical charts load as expected. If issues persist, ensure all SolarWinds services on the APE are restarted properly.
