Tools
The incoming syslog messages are truncated if it's more than 1024 bytes is sent in Kiwi Syslog NG v1.0.0.24
Syslog messages of about 2048 characters but KSS NG v1.0 received only 1497 out of 2024 characters.
12/4/2023 3:12 AM
12/4/2024 11:07 PM
Syslogs are truncated even during the initial parsing.
And the default KSS NG config: " MaxSyslogMessageLength": 8192. is ignored and large incoming messages (more than 1024 bytes) are truncated.
Steps to reproduce
1. Create a log to file action in KSS NG.
2. Use Kiwi Syslog Generator's MultiLine text message to send a 2048 character message to KSS NG as Kernel.Emergency<0>.
3. Check debug logs.
Actual behavior:
The incoming syslogs are truncated if it's more than 1024 bytes.
Expected behavior:
  • The full incoming syslogs should be processed.
  • The ability to set the number of characters to receive (like in legacy KSS)
This issue is fixed in Kiwi Syslog NG v1.1: KSS NG 1.1 Release Notes
Kiwi Syslog Server
This is a known issue in Kiwi Syslog NG v1.0.0.24.
Upgrade to Kiwi Syslog NG v1.1.
For more info, please check installation and upgrade guide: Kiwi Syslog Server Installation and Upgrade Guide
