Applications Systems
Test failed with "Unknown" status on xxxxx Node Provider load failure
When testing a Windows Service Monitor, the following error appears: Test failed with "Unknown" status on xxxxx Node Provider load failure
Open the SolarWinds Platform Web Console.
Click Settings > SAM Settings > Manage Templates.
Edit the Template in question.
Expand Advanced.
Switch "Platform to run polling job on:" to x86.
Submit the changes.
