NCM error: Test failed. Connection refused by x.x.x.x
This article explains how to resolves the NCM connection profile test failure.
when performing a test in Connection Profile under Edit Settings view of an NCM node. You encounter the Test Failed. Connection Refused by x.x.x.x error . When you click Login Details, you notice that a different Connection Profile is assigned it will show connection profile SSH Cisco.
To resolve this issue, take the following steps:
3. Delete the old (corrupted) Connection Profile.
Another Resolution is to use a working Connection Profile.
Ask user to test a working Credential by accessing the device from Solarwinds Server via Putty
If the credential is not yet in the selection of NCM connection profiles, please add it by following the link to Step 2 above.
