System.FormatException: The input is not a valid Base-64 string as it contains a non-base 64 character
Orion NPM is not processing all incoming syslogs with an error message saying the input is not a valid Base-64 string.
10/18/2018 6:26 AM
9/20/2022 1:43 PM
Orion NPM is not processing all expected Syslog messages when a device forwards syslogs. On the log 'C:\ProgramData\SolarWinds\Logs\Orion\SyslogService.log' will contain the following error:
WARN SolarWinds.Syslog.SyslogPacketBase - Decode packet failed, packet missing starting '<'
- Error Decoding Packet
System.FormatException: The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters.
at System.Convert.FromBase64_Decode(Char* startInputPtr, Int32 inputLength, Byte* startDestPtr, Int32 destLength)
at System.Convert.FromBase64CharPtr(Char* inputPtr, Int32 inputLength)
at System.Convert.FromBase64String(String s)
at SolarWinds.Syslog.SyslogPacketBase.DecodePacket(Boolean enableRfcRelay)
Network Performance Monitor
The received Syslog was forwarded to Orion instead of originating with the device sending the Syslog to Orion.
  1. Access the advanced configuration setting: Advanced Configuration access in Orion Platform
  2. Locate: SyslogService.SyslogSettings
  3. Set: EnableRfcRelay to enable or put a check on a box
  4. Save settings
  5. Restart Orion services
