Security Compliance
Syslogs Node in SEM using wrong IP
The way the SEM receives syslogs may cause the expected IP address to be different than the IP address used in SEM.
10/18/2018 7:41 PM
10/18/2018 7:41 PM
The way Security Event Manager (formerly Log & Event Manager) receives syslogs may cause the expected IP address to be different than the IP address used in SEM.
SEM's syslog collector is set to use the UDP source address of incoming syslogs rather than the IP address or hostname in the syslog message. This normally does not pose a problem except when relaying syslog messages are using a node with multiple IP addresses. If possible, IP spoofing will need to be used to correct the node IP.
