Syslog or Traps warning above threshold reached (Legacy Orion Syslog and Traps)
This article describes how to address the issue where the Orion Console displays a warning that the Syslog or Traps table has run out of space.
10/18/2018 6:27 AM
8/23/2023 2:40 AM
Note: This only applies to Legacy Orion Syslog and Traps
This won't apply for Orion Log Analyzer / Viewer
The Orion Console displays a warning that the Syslog or Traps has reached a specific number of rows, which is above the predetermined warning threshold.
Network Performance Monitor
Increase or Decrease Syslog Row count value
Perform one of the following procedures:
  • Adjust the Syslog or Trap message threshold in your Orion database
  • Reduce or delete the Syslog or Trap message threshold in your Orion database.
If you need to keep a large number of Syslogs or Traps for operational needs, adjust the threshold.
Adjust the Syslog or Trap message threshold in your Orion database (Note: Increasing Default values may have a negative DB performance impact for your Orion DB)
  1. Back up your Orion database.
  2. Go to Start > All Programs >SolarWinds Orion > Advanced Features > Database Manager.
  3. Click Add Default Server.
  4. Expand your SQL server Instance Name
  5. Locate Orion DB > Right-click on it and click New Query
  6. Adjust your Syslog warning threshold (if required) and execute:
    Update settings set Currentvalue = xxxxxxxx Where SettingID = 'Syslog-MaxRowCount'
    Note:  xxxxxxx equals to the new threshold.
  7. Adjust your Traps warning threshold (if required).
    Execute:
    Update settings set Currentvalue = xxxxxxxx Where SettingID = 'Trap-MaxMessageAge'
  2. Go to Start > All Programs > SolarWinds Orion > Advanced Features > Database Manager.
  4. Expand your SQL instance, normally Netperfmon or Solarwinds.
  5. Right-click Syslog or Traps and then click Query Table.
  6. Clear the provided query.
  7. Enter the following query to delete all Syslog messages, Traps, and trap variable bindings older than a designated date (which you can change as desired).
    Execute:
    Delete from Syslog Where datetime <= '4/1/2016 12:59 AM'
    Delete from Traps Where datetime <= '4/1/2016 12:59 AM'
    Delete from TrapVarBinds where TrapID not in (select TrapID from Traps)
  8. (Optional) Delete all existing Syslog messages, Traps, and trap variable bindings using the following Truncate commands:
    Truncate Table Syslog
    Truncate Table Traps
    Truncate Table TrapVarBinds
    You may also like to check out Tips and tricks for managing traps and syslog in Orion NPM
    and Retention Settings for Syslogs and Traps
