Syslog and traps are not forwarding to hostname
This article will show how to correct an issue with OLV where the Syslog and Traps are not forwarding to hostname showing Importing 'CSM Syslog Forwarding' ... FAILED and/or Invalid address to forward to: *HOSTNAME*.
The OLV logs will show the following error when it fails to forward logs to another server:
[03/30/22 19:05:23] Importing 'CSM Syslog Forwarding' ... FAILED
[03/30/22 19:05:23] Invalid address to forward to: *HOSTNAME* (166a527a-d164-4951-b0bf-4581c128924d)
[03/30/22 19:05:23] Importing 'CSM Trap Forwarding' ... FAILED
[03/30/22 19:05:23] Invalid address to forward to: *HOSTNAME* (2a63f663-34ac-47da-961c-21bd1757e685)
ForwardTo set to: SHORT
[03/30/22 19:06:04] Importing 'CSM Syslog Forwarding' ... FAILED
[03/30/22 19:06:04] Invalid address to forward to: *HOSTNAME* (166a527a-d164-4951-b0bf-4581c128924d)
[03/30/22 19:06:04] Importing 'CSM Trap Forwarding' ... FAILED
[03/30/22 19:06:04] Invalid address to forward to: *HOSTNAME* (2a63f663-34ac-47da-961c-21bd1757e685)
ForwardTo set to: IP
[03/30/22 19:07:01] Importing 'CSM Syslog Forwarding' ... SUCCESS
[03/30/22 19:07:01] Importing 'CSM Trap Forwarding' ... SUCCESS
1. Verify log forwarding is correct
2.Run tests:
2a. NSlookup the target hostname on CMD on polling engine
2b. Pingtest target hostname from polling engine
3. From here we have 3 options:
3a. Correct DNS issue
3b. Use IP address instead of hostname
3c. Update hosts file
