Supported vendor OIDs for VLAN monitoring in Orion NPM
This article provides a detailed list of vendor OIDs used by Orion NPM for VLAN monitoring. It also includes Generic OIDs.
This article provides detailed list of OID(s) used by Orion NPM in VLAN monitoring.
Please note for VLAN naming convention we use the standard
vtpVlanName OBJECT-TYPE
SYNTAX DisplayString (SIZE (1..32))
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The name of this VLAN. This name is used as the ELAN-name
for an ATM LAN-Emulation segment of this VLAN."
VLANs over 32 char will not display on the website.
Below is comprehensive list of vendors and corresponding OID(s):
3Com
| MIB | OID (NAME) | OID (NUMERIC) |
| A3COM-HUAWEI-LswVLAN-MIB | hwdot1qVlanName | 1.3.6.1.4.1.43.45.1.2.23.1.2.1.1.1.2 |
| hwVlanInterfaceAdminStatus | 1.3.6.1.4.1.43.45.1.2.23.1.2.1.2.1.5 | |
| hwdot1qVlanPorts | 1.3.6.1.4.1.43.45.1.2.23.1.2.1.1.1.3 | |
| A3COM-HUAWEI-LswINF-MIB | hwifVLANType | 1.3.6.1.4.1.43.45.1.2.23.1.1.1.1.5 |
Cisco
| CISCO-VTP-MIB | vtpVlanTable | 1.3.6.1.4.1.9.9.46.1.3.1 |
Hewlett-Packard (HP) check GENERIC
Juniper
| JUNIPER-VLAN-MIB | jnxExVlanName | 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.2 |
| jnxExVlanInterfaceOperStatus | 1.3.6.1.4.1.2636.3.40.1.5.1.6.1.7 | |
| jnxExVlanPortGroupInstance | 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.4 | |
| jnxExVlanPortAccessMode | 1.3.6.1.4.1.2636.3.40.1.5.1.7.1.5 | |
| jnxExVlanTag | 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.5 | |
| jnxExVlanPortStatus | 1.3.6.1.4.1.2636.3.40.1.5.1.7.1.3 |
Generic
| DOT1Q-BRIDGE-MIB | dot1qVlanFdbId | 1.3.6.1.2.1.17.7.1.4.2.1.3 |
| dot1qVlanStaticName | 1.3.6.1.2.1.17.7.1.4.3.1.1 | |
| dot1qVlanCurrentEgressPorts | 1.3.6.1.2.1.17.7.1.4.2.1.4 |
Common
| BRIDGE-MIB | dot1dBasePortIfIndex | 1.3.6.1.2.1.17.1.4.1.2 |
IMPORTANT NOTE
Make sure that your device does list ALL of the OID(s) listed under the vendor specific OID(s) as well as Common ones only then the VLAN will be listed. If any of them will be missing the VLAN poller will be ignored.For example Juniper:
- jnxExVlanName - 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.2
- jnxExVlanInterfaceOperStatus - 1.3.6.1.4.1.2636.3.40.1.5.1.6.1.7
- jnxExVlanPortGroupInstance - 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.4
- jnxExVlanPortAccessMode - 1.3.6.1.4.1.2636.3.40.1.5.1.7.1.5
- jnxExVlanTag = 1.3.6.1.4.1.2636.3.40.1.5.1.5.1.5
- jnxExVlanPortStatus = 1.3.6.1.4.1.2636.3.40.1.5.1.7.1.3
- dot1dBasePortIfIndex = 1.3.6.1.2.1.17.1.4.1.2
