Supported Operating System Failure
This article describes the issue when you are upgrading NPM and receive this error: Your Operating System is Not Supported or The operating system is not supported. Please upgrade your operating system, and then run the SolarWinds Installer again.
10/15/2018 1:11 PM
3/21/2022 11:50 AM
This article provides information regarding possible reasons for operating systems causing possible failures.
Network Performance Monitor
SolarWinds products do not support Windows 2003, 2008 (non-R2), XP, 7, Vista, 8.x Standard edition.
SolarWinds strongly recommends that you upgrade to Microsoft Windows Server 2016 or later.
Microsoft Windows Server support varies for each SolarWinds product. See Windows Server 2012, 2016, and 2019 and SQL Server 2012, 2014, 2016, 2017, and 2019 Support and review the product list to verify supported Windows Server versions.
For further requirements and notices, see the system requirements and release notes for each product and version.
For the MS Server versions supported by the latest Orion Platform version, see Orion Platform requirements.
See this video for information on the advantages of upgrading Orion Platform products from a 2012 infrastructure.
