Submit a feature request for SolarWinds Products
The article tackles the process of how to submit a feature request for SolarWinds Products.
10/18/2018 6:30 AM
11/3/2026 10:58 PM
This article describes how to submit a feature request to SolarWinds. Feature requests and votes by you and other SolarWinds users help SolarWinds plan updates and additions to services and modules. All feature requests can be entered through THWACK. Our Product Managers monitor THWACK forums.
In these forums, you can voice your opinions on whether you find certain features useful.  You may also call support to request a ticket for your feature request, or use the Customer Portal to create one. Make sure to indicate Feature Request in the title.
Orion Platform
To request a feature for a specific product:
  1. Navigate to Thwack.
  2. From the banner at the top, select Products > the product to submit a feature request for. For example, Products > SolarWinds Observability Self-Hosted.
  3. On the main page for the product, select Feature Requests > New Idea and fill out the Create Post form to submit your feature request.
You may also be interested in:
Please be aware that:
  • Developers will decide on whether or not to go ahead with the implementation of the feature.
  • Developers will decide on the timeline of the release (if they decided to implement the feature)
Support does not update you on whether the feature has been implemented. To see what features are being added to a product, check product blogs on THWACK, Product Release Notes, and feature overviews per release. Release notes are found here:
SolarWinds Documentation
