String values assigned to a cell cannot have a length greater than 32767
When exporting NCM rule to excel file the following message appear: Error: "String values assigned to a cell cannot have a length greater than 32767".
10/22/2018 4:31 PM
1/17/2025 2:31 PM
This article explains the reason for the following error message when exporting an NCM rule to MS Excel:
String values assigned to a cell cannot have a length greater than 32767.
Network Configuration Manager
Based on the Microsoft document - (© 2022  Microsoft, available at Excel specifications and limits, obtained on 2022), the total number of characters that a cell can contain is 32,767 characters.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
