Applications Systems
Storage capacity forecasting and planning
Storage capacity planning can be a complex task, especially in a virtualized infrastructure. It involves manually creating complex spreadsheets. Storage Resource Monitor automates the collection of forecasting data so you can easily see growth rates, forecast costs and budgetary requirements, and project when capacity will be reached.
See the Capacity Planning section in the Getting Started Guide for an introduction to capacity planning with SRM, or see the following online help topics:
- Active Storage Alerts
- Storage Objects by Storage Capacity Risk
- Thin Storage Pools by Capacity or Thin Storage Pools
- Thick Storage Pools by Capacity or Thick Storage Pools
- Thin LUNs by Capacity or Thin LUNs
- Thick LUNs by Capacity or Thick LUNs
- Thin NAS Volumes by Capacity or Thin NAS Volumes
- Thick NAS Volumes by Capacity or Thick NAS Volumes
- Server Volumes by Capacity
