Applications Systems
Special character not escaped in PowerShell Script
In SAM, PowerShell scripts used for Microsoft.PowerShell session configuration contain a placeholder of ${PASSWORD} as seen in this code: $password = '${PASSWORD}' You should replace the placeholder including the single quotes. SAM does not escape the single quotes. If you do not remove the single quotes, data may not poll for AppInsight for IIS.
10/23/2018 6:40 PM
6/3/2020 8:00 AM
Server Application Monitor
Single quotes for the password placeholder are not escaped. You should replace these when adding a password for the PowerShell script.
Please Remove the Quote ' or Backtick `  from the password
