SolarWinds agent does not start due to a certificate mismatch in Orion Platform products
This article describes an issue that prevents the SolarWinds agent from starting due to a certificate mismatch. When this issue occurs, the following error message displays: "The client certificate does not contain a valid UPN, or does not match the client name in the logon request."
The SolarWinds agent does not start due to certificate mismatch.
Full error message popup:
Error 0x8009033d: The client certificate does not contain a valid UPN, or does not match the client name in the logon request.
Pleaes contact your administrator
- Server is using an old certificate or the server certificate was replaced.
- The client certificate does not contain a valid UPN or does not match the client name in the logon request.
Resolution 1:
Reprovision the Orion Agent. This can be done on Windows through the Control panel on the agent machine. Or it can be performed by navigating directly through the following executable:C:\Program Files (x86)\SolarWinds\Agent\SolarWinds.Agent.Service.exe
See here for more details.
Resolution 2:
- Open the Control Panel.
- Uninstall the SolarWinds Agent.
- Log in to the Orion Web Console.
- Click Settings > All Settings.
- Under Node and Group Management, click Manage Agents.
- Downloaded and install the SolarWinds Agent msi.
Check this article: Unable to deploy Agents: Unable to get provision certificate bytes for agent deployment
