Security Compliance
SolarWinds SEM Agent benefits and best practices
This article discusses the SolarWinds SEM Agent benefits and best practices.
Benefits of the SEM Agent
- Secure, efficient communication
In new installations of SEM (6.7 and newer), corresponding agent versions communicate by default using a secure certificate, which no longer requires TLS 1.0, 3DES, or anonymous cipher. If you need to connect to earlier agent versions, navigate to the SEM Events Console security tab (Settings > Security), and switch the toggle button to enable lower security settings.
The SEM Agent (versions 6.6 and older) uses Secure Socket Layer\Transport Layer Security (SSL/TLS), which is a bandwidth-friendly encryption and compression technology, which provides secure communication with the SEM Manager and ensures the impact on the network is very small. This secure, real-time communication is especially important for data integrity as it sends the logs to a secure collection point before they are exposed to potentially being manipulated or deleted.
- Centralized logging
Once the SEM Agent normalizes the logs it collects, it sends the normalized alerts to the SEM Manager for real-time monitoring, powerful correlation, efficient reporting, and long-term storage. - Alert correlation
Alert correlation is at the heart of what SEM does. It allows you to compare log files from a variety of sources to identify patterns that are indicative of a variety of networking issues, external threats, and insider abuse. - Local visibility
Your firewall does not log everything, nor do your domain controllers. The SEM Agent provides additional visibility at the “local” level for events on workstations and member servers that otherwise might be missed. Software installations and logon failures are just two examples. - USB device monitoring
USB Defender is a free add-on for all SEM Agents installed on Windows computers. It tracks events related to USB mass storage devices like flash drives and smart phones, and allows the SEM Manager to send commands to detach offending devices both manually and automatically. - Active response
There are several active responses built into the SEM Manager and some of them require a SEM Agent to execute them. Examples include logging off a user, shutting down a computer, and detaching a USB device.
Deployment best practices
- Deploy to domain controllers for broad coverage
When planning your deployment in a domain environment it is especially critical to install the SEM Agent on all domain controllers, which make up the central repository for most audit data. From these computers you will gather critical security events, such as domain-level account lockouts, change management events, and privileged account activity. Remember that not all events are replicated between domain controllers, so we recommend installing a SEM Agent on all domain controllers. - Deploy to workstations and member servers for local coverage and active response
Even in a domain environment, certain events are not replicated to the domain controllers from member servers and workstations. These events include logon activity, local change management events, file audit events, process and service activity, and local antivirus events.
Furthermore, some active responses are dependent on the target operating system, making the SEM Agent a prerequisite. Examples of agent-dependent active responses are noted above, but it’s worth mentioning the Detach USB Device action again since it’s driven by USB Defender – a service that provides more than just active response. Additionally, USB Defender tracks all attach, detach, and file audit events for all USB mass storage devices that are attached to a SEM Agent with the USB Defender service installed. - Deploy to workstations or servers to monitor antivirus events
Antivirus is another consideration. Where you deploy your SEM Agents will also depend on where your antivirus logs. If it logs to an antivirus server, a SEM Agent on that server will do the trick. However, if it logs at each endpoint, the SEM Agent will be needed on each computer in order to effectively track and respond to antivirus events with the SEM Manager
