Tools
Slow or laggy display performance during a remote session in Dameware Mini Remote Control (MRC)
This article shows an alternative way to improve the display performance of Dameware.
5/1/2020 9:29 PM
5/1/2020 9:29 PM
There is some situation that a Mini Remote Control user will experience display performance issues such as slow or laggy resolution during the remote session. Usually, it happens when a host or remote user not directly connected to the local network or connected via a VPN.
Dameware Remote Support & Mini Remote Control
Possible network congestion issues or, if connected via VPN, VPN configuration issue
You may perform network troubleshooting if you find network issues and check the VPN configuration. You may also perform the following:
1. In Mini Remote Control, click View.
2. Select Default Host Properties.
3. Select the box "Use Slow Link Optimization."
4. Click Apply, then OK.
5. Select Apply All.
