Skip Not Monitored Devices using Orion Syslog
Set Orion Syslog to skip devices that are not added as a Node in Orion.
4/22/2019 8:56 PM
4/22/2019 8:56 PM
This article describes how to stop receiving syslog messages from nodes that are not monitored by Orion NPM.
Network Performance Monitor
The Orion server is receiving Syslog Messages from unmonitored nodes.
  1. Login to the Orion Web Console.
  2. Navigate to this URL: http://OrionServerIP_Hostname/Orion/...on/Global.aspx.
  3. Under SyslogService.SyslogSettings:
    1. Locate SkipNotMonitoredDevices - Checkbox (default is unchecked).
    2. Select to Skip (Enable).
  4. Save and Restart Orion Services to take effect.
