Observability
Setting up Remote_Syslog2 on Solarwinds Observability
This article provides step-by-step instructions on setting up the remote_syslog2 for Solarwinds Observability
Log messages for the Linux host entity can be sent to the SolarWinds Observability account via remote_syslog2 logging configuration.
- Follow the provided instructions here for the manual installation.
- For the configuration, modify the /etc/log_files.yml to look like the one below. The host should be syslog.collector.xx-yy.cloud.solarwinds.com, where xx-yy is determined by the URL you use to access SolarWinds Observability, described in Data centers and endpoint URIs. The token can be seen in the manual setup instructions within the "Add Data" wizard for Logs in the SWO UI.
files: - /path/to/your/file.log destination: host: syslog.collector.xx-yy.cloud.solarwinds.com port: 6514 protocol: tls token: 012345-XXX-XXXX-XXXX
3. Save changes made on the .(dot) yml file.
4. Rerun the remote syslog using the command:
sudo remote_syslog
5. Please make sure that you're running the latest version of remote_syslog2 by running this command:
remote_syslog --version
6. Check and verify if the logs are coming in on your Logs UI of the SolarWinds Observability.
