Applications Systems
Setting a fixed port for WMI nodes
This article allows you to see information from Microsoft on setting up a fixed port for WMI. SolarWinds does not provide support in connection with setting up a WMI.
10/9/2018 4:49 PM
9/4/2025 8:09 PM
Server Application Monitor
Note: The following instructions are based on the Microsoft article located here
SolarWinds does not provide support concerning the following information:
To set up a fixed port for WMI, perform the following on the node polled by the SolarWinds server:
  1. At the command prompt, type:  winmgmt -standalonehost
  2. Stop the WMI service by typing the command:  net stop "Windows Management Instrumentation"
  3. Restart the WMI service again in a new service host by typing:  net start "Windows Management Instrumentation"
  4. Establish a new port number for the WMI service by typing:  netsh firewall add portopening TCP 24158 WMIFixedPort
  5. WMI ports are TCP Port 135 and by default, all TCP ports from 1024 to 65534
