Tools
Set up multiple instances of Web Help Desk
This article provides step by step procedure on how to setup multiple instance of Web Help Desk
- For Node 1 is the first WHD instance to be set up. Activate the license at the first start up.
- For Nodes 2, 3 4 and 5, install WHD and stop the service.
- Copy the files from step 1's configuration folder to the
<WebHelpDesk>/conffolder of each Node (2, 3, 4 and 5):- whd.conf
- keystore.jks (if you have HTTPS)
- .whd.properties (this contains the DB connection info)
- Modify the
<WebHelpDesk>/conf/tomcat_web_template.xmlfile and set the Daemon Mode tonone(should be the on the last 4 lines):from:
<env-entry-name>WHDDaemonMode</env-entry-name> <env-entry-type>java.lang.String</env-entry-type> <env-entry-value>background</env-entry-value>
to:
<env-entry-name>WHDDaemonMode</env-entry-name> <env-entry-type>java.lang.String</env-entry-type> <env-entry-value>none</env-entry-value>
- Add the JVM Argument
-DClusterSecondaryNode=trueto the configuration.
For Windows:
Edit the conf file<WebHelpDesk>/bin/wrapper/conf/wrapper_template.confthen add the following line in the# Java Additional Parameterssection of that file setting the next sequential number in the list:wrapper.java.additional.<NUMBER>=-DClusterSecondaryNode=true
For Mac or Linux:
where<NUMBER>is the next proceeding number.
Edit<WebHelpDesk>/conf/whd.confthen add the following line at the end of the config file:JAVA_OPTS="-DClusterSecondaryNode=true"
- Make Node 1 the dedicated daemon instance, that way, all it does is run the WHD daemons especially for heavy emails and database interactions.
- Edit the
<WebHelpDesk>/conf/tomcat_web_template.xmlfile and set the Daemon Mode to dedicated (should be the on the last 4 lines):
from:<env-entry-name>WHDDaemonMode</env-entry-name> <env-entry-type>java.lang.String</env-entry-type> <env-entry-value>background</env-entry-value>
to:<env-entry-name>WHDDaemonMode</env-entry-name> <env-entry-type>java.lang.String</env-entry-type> <env-entry-value>dedicated</env-entry-value>
- Since this machine is no longer offering the Web UI, you will have to take it off the pool for from your load balancer.
- Edit the
- In your load balancer, enable Sticky sessions as WHD will require this for tracking sessions.
- Restart all WHD instances.
