Set up an alert when a node or interface is deleted
This article describes how to set up an alert when a node or interface is deleted.
- Log in to the Orion Web Console.
- Go to Settings > Manage Alerts.
- Specify a name for your alert then proceed to Trigger conditions.
- Select "I want to alert on" - Auditing Event.
- Set up the following OR trigger conditions. If Action Type is unavailable, click Browse All Fields then search for it :
- Auditing Event - Action Type - is equal to - Node Deleted
- Auditing Event - Action Type - is equal to - Interface Deleted
- Proceed through the next steps.
