Tools
Set up Serv-U with a public IP to connect to a Gateway with private IP
This article describes how to set up Serv-U with public IP to connect to a Gateway with a private IP address.
11/29/2018 10:56 PM
5/13/2019 7:52 PM
  • If you use Serv-U version 15.1.1, apply 15.1.1 Hotfix 1.
  • If you use Serv-U version 15.1.2 or higher:
  1. Create a file with the name Serv-U-Gateway.ini with the following content:
    [IPRestrictions]
    PrivateGWpublicSERVU = 1
  2. Place the file in the installation folder of Serv-U Gateway.
