Set the status thresholds for Universal Device Poller using Web Console
Configure up, warning, and critical thresholds to be used by Universal Device Poller.
The Universal Device Poller (UnDP) has three statuses, namely:
- Up (green),
- Warning (yellow)
- Critical (red)
From the Web Console you can set the threshold values for the Warning and Critical states.
- Click Web Console > Settings > All Settings > THRESHOLDS & POLLING > Custom Poller Thresholds.
- Click on a Custom Poller on the left panel.
- Specify Poller Value Type - Text or Number (Check if your poller returns number or text)
- Specify values for Warning Threshold and Critical Threshold.
- Click Submit.
