Set connection profiles to auto-detect in NCM
This article details how to set a connection profile in Network Configuration Manager (NCM) to auto-detect and set a node to a connection profile to auto-determine which profile to use.
- Go to NCM Settings > Connection Profiles under Global Device Defaults.
- For each profile, edit and check the box to enable automatic use at the bottom.
- Go to Configuration Management and select desired nodes.
- Click on Edit Properties.
- Scroll to the bottom for Connection Profile
- Under Global Connection Profile, select Auto Detect.
- Save changes.
