Applications Systems
Services Monitor - WMI vs RPC vs SNMP
Information for monitoring options via: SNMP (MIB OIDs) WMI (WMI Counters) and Windows Performance Counters (RPC)
10/9/2018 4:43 PM
1/7/2022 6:00 PM
Protocols to monitor Services in SAM
Basically you can monitor Services via:
  • SNMP (MIB OIDs)
  • WMI (WMI Counters) and
  • Windows Performance Counters (RPC)
Server Application Monitor
SNMP
  • For example in SAM you don't see what SNMP is being monitored, but pulls from likes of these OID's 1.3.6.1.2.1.25.4.2.1.x HOST-RESOURCES-MIB.
  • SNMP requires much less bandwidth to poll than WMI.
  • Some details on this: SNMP and WMI polling comparison
It uses its own SNMP service, does not use the RPC service.
SAM help reference material:
An advantage to SNMP also is that it will retry the poll 3 times before marking it as unknown.
- WMI is not capable of doing at the moment.
- If the WMI query fails to get a response on first attempt, it marks the component as unknown. SNMP will try 2 more times, then mark it as unknown.
​WMI
  • WMI Monitor
  • Example of how we use WQL to pull Services:
  • SELECT * FROM Win32_Service
    SELECT * FROM Win32_Process
    SELECT * FROM Win32_PerfRawData_PerfProc_Process
  • Testing WMI Connectivity
RPC
  • Windows Service Monitor
    Windows Performance Counters (RPC):
  • This is same as running cmd -> PERFMON
  • On windows Servers the Operating System maintains all this counters and we can pull from them.
  • RPC & SNMP has a retry feature which means that it will try to collect the data up to three times should it fail on any of the first polls
Also there are Documents on WMI\SMNP on site in links below and Videos Tutorials.
Orion Demo
  • SolarWinds Online Orion Demo
  • Look at demo site to see fully up and running Demo of Orion and all its Modules,
  • Here you can see Various views and devices being monitored along with other interesting Orion Modules like SAM, VNQM, IPAM, NTA.
