Tools
Serv-U Management Console is freezing, sluggish, unresponsive, and connection from Users is timing out
This article describes the issue in the Serv-U Management Console, which is freezing, sluggish, and unresponsive, and the connection from users is timing out.
10/19/2021 4:32 PM
3/31/2025 10:40 PM
In this issue, the Serv-U Admin is experiencing an issue navigating and managing the Serv-U Management console, which is unresponsive. Even the Serv-U Icon Tray is not responding.
The Admin console is very sluggish, and not loading promptly. It also affected the Users' connection and took more than a minute before users could log in and authenticate, affecting the automated jobs to run, and transfer files.
The issue will persist unless the Serv-U service is restarted by killing the service from the task manager and relaunching the Serv-U management Console which causes Serv-U downtime.
The Users Home Directory was pointed to Faulty Drive/Disk or Drive/Disk is full.
Option 1:
Check the User's home directory and make sure that the Drive/Disk is not full or has enough space.
Option 2:
If there are changes in the Network Drive, double check the previous network drive settings on the Serv-U match your new Network Drive details.
Option 3:
Reconfigured Serv-U to read the fixed Faulty Drive.
Pre-Implementation Steps
  1. Create a Server Snapshot
  2. Create a copy of the Serv-U Configuration files below and put them in the safe location:
    • Serv-U.Archive file
    • Users folder
    • Shares folder
    • Serv-UID.txt file
  1. Stop Serv-U Services
  2. Delete the Users folder and Serv-U.Archive file
    • These files are either stored in:
      • Windows Vista/7/8, Server 2008/2012 - C:\ProgramData\RhinoSoft\Serv-U (ProgramData Folder is Hidden in Windows by default)
      • Windows 2000/XP, Server 2000/2003 - C:\Program Files\RhinoSoft\Serv-U
  3. Start Serv-U Services
    • A new and blank Serv-U.Archive file was created.
  4. Recreates the same domain and Site name. Navigate the Console, it is now responsive.
  5. Stop Serv-U Services and restore the same Users folder
  6. Start Serv-U Services, browse the console. We experienced the same symptoms.
    • Serv-U Management is very sluggish, and not loading in a timely manner
  7. Remove all Users, retain one Domain Users, the same issue.
  8. We change the Home Directory, point to another drive particularly to Drive C
  9. Restart Serv-U Services
  10. Launched and Navigated the Console, now responsive.
    • Confirmed that this Users Home Directory Issue, the Users Home Directory was pointed to Faulty Drive/Disk
  11. Created a new Drive and pointed and moved the User's file.
After the changes, the Serv-U Application has become responsive and stable.
