Tools
Serv-U MFT Server MFA intermittently fails for users authenticating with Duo Mobile rotating TOTP codes
This article describes an issue where Serv-U MFT Server MFA intermittently fails for users authenticating with Duo Mobile rotating TOTP codes, while users on Microsoft Authenticator or Google Authenticator are not affected.
When MFA is enabled for the Serv-U web client, some users who use Duo Mobile for TOTP codes experience intermittent MFA failures:
- Users enter the 6‑digit Duo code shown on their device
- Serv-U rejects the code as invalid, even though it appears correct to the user.
- The same Serv-U instance works reliably for other users using Microsoft or Google Authenticator, with no MFA failures reported.
Serv-U uses standard TOTP-based MFA for web logins:
- Generates 6‑digit one-time codes
- Each code is valid for 30 seconds only
- TOTP algorithm: SHA‑1
- The 30‑second validity window is fixed and cannot be configured in the current product; there is no UI/setting to extend this window
Serv-U does not differentiate between Duo, Microsoft Authenticator, or Google Authenticator:
- All three apps generate TOTP codes according to the same standard.
- Serv-U only validates:
- The numeric TOTP value and
- That it is within the allowed 30‑second time window.
Why Duo users see more failures
- Duo Mobile emphasizes a “rotating” OTP UI, where:
- Users often enter the code near the end of the 30‑second countdown, or
- Just as the code rotates to a new value.
In these situations:
- By the time the user submits the code, Serv-U may already consider that TOTP expired, resulting in an MFA failure.
- Users of Microsoft or Google Authenticator, due to different UI/usage habits, are more likely to enter the code earlier in the 30‑second window, so they do not typically see failures.
Therefore, this is best classified as a product behavior/limitation of the fixed 30‑second TOTP window, made more visible by Duo’s rotating-code UX, rather than a Serv-U defect.
1. Timing discipline when entering Duo codes.
Advise affected users to adjust how they enter Duo codes:
- Enter the code immediately after a new code appears in Duo Mobile, rather than waiting until the end of the countdown.
- If a code fails and the app is about to rotate:
- Wait for the next full 30‑second cycle,
- Then enter the new code promptly at the start of that window.
This maximizes the chance that Serv-U receives the TOTP while it is still within its valid 30‑second window.
2. Verify time synchronization (server and client)
Any time drift between the Serv-U server and the user’s mobile device effectively shortens the TOTP validity window and increases the chance of failures.
On the Serv-U server:
- Ensure the OS system clock is accurately synchronized using a reliable NTP source.
- Confirm that time zone, date, and time are correct and stable.
On user devices:
- Ask users to set their mobile devices to automatically update date and time from the network or a trusted time source.
- If possible, verify that the device time is not noticeably ahead/behind actual time.
Good time synchronization helps keep the full 30‑second window usable for MFA.
3. Optional: Standardize on Microsoft/Google Authenticator
If Duo users continue to experience issues despite the above:
- Consider standardizing on Microsoft Authenticator or Google Authenticator for Serv-U MFA, as they have been reported to work reliably in our customers’ environment.
This is an operational workaround until Serv-U provides configurable MFA timing options.
