Tools
Serv-U – Java dependency and legacy web clients
This article provides information on Serv-U Java dependency and it's leagcy web clients when assessing Java-related vulnerabilities.
Users may need to confirm whether Serv-U relies on Java on the client side or server side, especially when assessing Java-related vulnerabilities or planning to remove Java from the server.
Starting from Serv-U 15.5.2, the legacy Java-based web clients were removed and replaced by the new Serv-U Client, so the product no longer depends on Java.
Serv-U historically used Java only for legacy web client components (FTP Voyager JV and Web Client Pro) when accessed in a browser; the core Serv-U service itself was never Java-based.
If users are running Serv-U 15.5.2 or later (including 15.5.4)
- Serv-U does not require Java on either the server side or the client side.
Note:
- To eliminate the Java dependency, plan an upgrade to Serv-U 15.5.2 or later, where those Java-based clients have been removed and replaced with the Serv-U Client.
- Before uninstalling Java, verify that no other applications on the same server require it.
