Tools
Serv-U HTTP or HTTPS web client login is not accessible
A possible issue where the web client is inaccessible.
- Run netstat -ano | findstr :443 on the command prompt, check the PID if this is Serv-U process.
- If so, change the HTTP or HTTPS listener port of Serv-U.
- Or change the HTTP or HTTPS listener port of the other service.
