Tools
Send commands to device configuration with CatTools
This article describes how to send commands to your device configuration with Kiwi CatTools.
- Open the Kiwi CatTools Console.
- In the Activities panel, click Add.
- When the activity opens, select Device CLI Send commands from the drop-down menu.
- Name the new activity, and check and confirm the data on the page.
- Go to the Time tab and set the schedule times and dates as required.
- In the Devices tab, select the device that you want to run the activity on.
- In E-mail tab, check and change the reporting data as required.
- Go to the Options tab, and enter the commands that you want to send to the device.
- Click OK.
