"Send SNMP Trap" execution fails for NPM
An error message is received when executing a test of the "Send SNMP Trap" alert in NPM.
execution has failed. System.Exception: Couldn't load Orion-Detailed-Alert!This message is found in the following NPM logfiles:
- \ProgramData\Solarwinds\Logs\Orion\ActionsExecutionAlert.log
- \ProgramData\Solarwinds\Logs\Orion\Alerting.Service.V2.log
- \ProgramData\Solarwinds\Logs\Orion\Core.BusinessLayer.log\
- \Program Files (x86)\SolarWinds\Common\Orion-Detailed-Alert.trap
- \Program Files (x86)\SolarWinds\Common\Orion-Generic-Alert.trap
- Verify all permissions are set correctly on the above folders and any antivirus exclusions are set appropriately. See Files and directories to exclude from antivirus scanning for Orion Platform products.
- If Step 1 does not resolve this issue, copy the following files to your SolarWinds program directory \Program Files (x86)\SolarWinds\Orion\:
- Restart all Orion services.
- If the issue persists, contact SolarWinds technical support for further assistance.
