Self-Led Project Plan for VoIP & Network Quality Manager (VNQM)
This article outlines a self-led project plan for onboarding SolarWinds Voice & Network Quality Manager (VNQM). It covers installation prerequisites, SolarWinds Platform integration, configuration of call managers and IP SLA operations, discovery of VoIP call paths, and setup of QoS thresholds. It also includes guidance for creating dashboards and maps, configuring alerts and reports, monitoring call quality trends, and leveraging QoS and other SolarWinds modules to optimize VoIP performance and troubleshoot issues efficiently.
Installation & Setup
Prepare to install VNQM
SolarWinds Platform requirements
Confirm VNQM Installation
Install or upgrade VoIP and Network Quality Manager
Configuration & Monitoring
Add Call Managers (CUCM / Avaya / Cisco SIP)
Add a call manager device to SolarWinds VNQM
Enable IP SLA Operations
Configure and manage Network Service Assurance operations.
Add Network Service Assurance operations
Designate Call Paths
For some of the SLA operations used by VoIP and Network Quality Manager, performance statistics are collected by sending traffic over paths between sites that you define.
Designate paths in SolarWinds VNQM
Understand how QoS metrics are derived
The quality of service in VNQM is measured by using the following metrics.
Quality of Service metrics in SolarWinds VNQM
Dashboards & Visualization
VNQM Views
Current network performance metrics in easy-to-review tables, graphs, and charts.
SolarWinds VNQM views
VNQM Maps
Add Network Service Assurance operations to SolarWinds maps, displaying their status just like other objects.
SolarWinds VNQM Maps
Alerts & Reporting
Configure Alerts
Set up real-time alerts for QoS thresholds and VoIP performance metrics.
Use alerts to monitor your environment with the SolarWinds Platform
VNQM Pre-defined Reports
Reports provided with a VoIP and Network Quality Manager installation.
Use predefined SolarWinds VNQM reports
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
