Self-Led Project Plan for Virtualization Manager
This article provides a step-by-step guide for self-led onboarding of SolarWinds Virtualization Manager (VMAN). It includes installation, integration with the SolarWinds Platform, configuration of monitoring settings, optimization recommendations, virtual storage management, alerting, reporting, and best practices to help you optimize virtual infrastructure performance and capacity planning effectively.
8/15/2025 9:25 PM
8/20/2025 4:58 PM
Installation & Setup
Confirm VMAN Installation
Ensure VMAN is installed and ready for configuration.
VMAN Installation Guide
System Requirements
Monitoring & Settings
Review ESX Host Hardware Health
Check and monitor ESX host hardware resources.
Hardware Monitoring & VMware
Configure VMAN Settings
Adjust VMAN-specific settings within the SolarWinds Platform.
Configure VMAN Recommendations
Nutanix Monitoring
Enable and configure monitoring for Nutanix virtual environments.
Monitor Nutanix Solutions
Hyper-V Monitoring
Enable and configure monitoring for Hyper-V virtual environments.
Monitor Hyper-V via SNMP/WMI
Recommendations & Optimization
Apply and Schedule Recommendations
Implement performance and resource optimization suggestions.
VMAN Recommendations Overview
Cloud Monitoring
Monitor AWS and Azure instances as SolarWinds Platform nodes.
Manage Cloud Instances as Nodes
Virtual Storage Management
Identify and Remove Zombie VMs
Detect and remove unused VMs to free resources.
Manage VM Snapshots
Monitor and remove unneeded VM snapshots.
Delete Snapshot of Virtual Machine
Remove Orphaned VMDKs
Identify and clean up unused VMDK files.
Identify Orphaned VMDKs
Plan Future VM Rollouts
Use historical data to guide new VM deployments.
VMAN Capacity Planning
Use PerfStack for Troubleshooting
Correlate VMAN data with PerfStack dashboards.
PerfStack Investigation
Alerts & Actions
Configure VMAN-Specific Alert Actions
Set up alerts with VMAN-specific variables and actions.
Available Alert Actions
VMAN Alerts
Reporting
Review Out-of-the-Box Reports
Access and review prebuilt VMAN reports.
VMAN Reporting Example
Create Custom Reports
Build new reports with VMAN-specific variables.
Create a Report for Specific VMs
Best Practices & Enhancements
  • Backup Configuration
  • Backup VMAN settings before major changes.
  • Use Custom Properties
  • Tag and organize VMs, hosts, and storage entities with custom properties.
  • Validate Environment Compatibility
  • Ensure VMAN is compatible with hypervisor versions, APIs, and platform integrations.
Notes
