Self-Led Project Plan for User Device Tracker
This article provides a self-led project plan for onboarding SolarWinds User Device Tracker (UDT). It includes installation requirements, SolarWinds Platform integration, discovery of switches and access points, and configuration of polling and user/device tracking.
Installation & Setup
Prepare to install UDT
Prepare to install or upgrade SolarWinds Platform products
Confirm UDT Installation
Install or upgrade User Device Tracker
Discovery & Monitoring
Add Nodes to UDT
Add switches, routers, and controllers required for device tracking.
Add SolarWinds Platform nodes to UDT
Manage Ports
Manage and monitor nodes and ports.
Port Management
User & Endpoint Tracking
Enable UDT Device Discovery
Discover and track end-user devices connected to the network.
Discover and add network devices to UDT
Configure Endpoint Alerts
Set up alerts for unauthorized devices or high-risk endpoints.
Configure a UDT alert
Reporting & Visualization
Run UDT Reports
Generate historical device tracking, port usage, and capacity reports.
UDT reports
Views and widgets in UDT
Highlights UDT’s dashboards and widgets used to locate devices, view connection history, monitor ports, and track users for faster network visibility and troubleshooting.
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
