Applications Systems
Self-Led Project Plan for Server Configuration Monitor
This article provides a self-led project plan for onboarding SolarWinds Server Configuration Monitor (SCM), covering installation prerequisites, platform setup, configuration of monitored nodes and profiles, baseline creation, change detection, dashboards and visualizations, alerting, and reporting to help track configuration changes, support compliance, and improve operational visibility.
Installation & Setup
Prepare to Install SCM
SolarWinds Platform requirements
Confirm SCM Installation
SCM Installation Guide
Configuration & Monitoring
Add Nodes and Manage Configurations
Add devices to SCM and configure monitoring of server and application configuration files/registry.
Add a node to SCM
Configure Profiles & Policies
Create configuration profiles and assign them to nodes to monitor critical files, registry settings, and services.
Server configuration profiles in SCM
Monitor Compliance
SCM offers a policy engine that enables you to monitor compliance of your servers, databases, and applications.
Monitor compliance with the SCM policy engine
Baseline & Detect Changes
Establish baselines and track configuration changes over time.
Learn about baselines in SCM
Dashboards & Visualization
Analyze Changes
Use comparison tools to see what changed, who made the change, and when it occurred.
Compare configurations over time in Server Configuration Monitor (SCM)
Alerts & Reporting
Configure Alerts
Set up alerts on configuration changes, file integrity monitoring, and policy violations.
Use alerts to monitor your environment with the SolarWinds Platform
Alert on SCM data
SCM Reports
Generate and schedule predefined SCM reports for audits and compliance requirements.
Create a web-based report in the SolarWinds Platform
Report on Server Configuration Monitor (SCM) data
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
