Self-Led Project Plan for Scalability Engines
This project plan provides a step-by-step guide for expanding your SolarWinds deployment using Scalability Engines, including Additional Polling Engines (APE) and Additional Web Servers (AWS). It covers installation, prerequisite validation, integration with the SolarWinds Platform, configuration of polling distribution and web access, performance tuning, and best practices to help you improve scalability, enhance monitoring capacity, and optimize user experience across large or distributed environments.
8/18/2025 4:59 PM
8/20/2025 5:37 PM
Installation & Setup
Review Scalability Guidelines & Requirements
Verify hardware, software, and network requirements for Scalability Engines deployment.
Scalability Engine Guidelines
Assist with Installation & Configuration Wizard
Walk through the Scalability Engines installation and complete the configuration wizard to connect it to the SolarWinds Platform.
Install Scalability Engines
Node Management for Additional Polling Engines (APE)
Change Polling Engine Assignments
Reassign nodes, interfaces, and volumes to the Additional Polling Engine (APE) for load balancing or optimized performance.
Configuration for Additional Websites (AWS)
Enable HTTPS for Secure Access
Install an SSL/TLS certificate to secure web traffic to the Additional Website.
Enable HTTPS in the SolarWinds Platform Web Console
Best Practices & Enhancements
  • Backup Configuration – Backup the SolarWinds Platform database before making changes to polling assignments.
  • Consider redundancy for your APE — deploy an Additional Polling Engine in High Availability to ensure failover protection.
  • Load Balancing on AWS – Consider using a load balancer to distribute traffic between Primary and Additional Web Servers.
  • Validate Environment Compatibility – Ensure the Scalability Engines are compatible with your SolarWinds Platform version and installed modules.
Notes
Orion Platform
