Database Management
Self-Led Project Plan for SQL Sentry
This article provides a step-by-step guide for self-led onboarding of SolarWinds SQL Sentry. Deploy and configure SQL Sentry to monitor SQL Server performance, configure alerts and actions, manage user access, and optimize database environments for scalability, availability, and diagnostics.
Installation & Setup
Install SQL Sentry
Use the Setup Wizard or Enhanced Platform Installer to install SQL Sentry.
SQL Sentry Installation Guide
Configure SQL Sentry Portal
Set up browser-based access to SQL Sentry data.
SQL Sentry Portal Configuration
Review System Requirements
Ensure your environment meets prerequisites.
System Requirements
Monitoring Configuration
Configure Monitoring Services
Set up monitoring services to collect performance and event data.
Monitoring Service Settings
Site Configuration
High Availability & Scalability
Database Maintenance
Scalability Pack
User Accounts & Permissions
Configure Security Settings
Security Overview
Assign Roles & Permissions
Manage user and group access to features.
Rights-Based Security
Alerts & Reporting
Configure Alerts & Actions
Generate Reports
Troubleshooting
Use Diagnostic Logs
Access logs for client, portal, and monitoring services.
Troubleshooting Guide
Resolve Common Issues
Fix client crashes, sync failures, and AlwaysOn tab issues.
Advanced Troubleshooting
Best Practices & Enhancements
Optimize Monitoring Scope
Settings Pane
Enable Performance Features
SQL Server Settings
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
